mirko088
to verify the summary is there a command?you need to check how much the total force applied and then apply a scale factor. I suggest you write the formula in excel, plot it, to verify it, then apply it and verify how much the sum is.
the rbe method has these advantages:
- apply forces to all knots, so you have no local effects of force having applied it to a few knots.
- you are very precise as a point of application of force, being released from elements
- It's a discreet system, so it can be controlled.
On the contrary, it is not easy to make all the rbes without interlacing between them.
See you..
