formulas in the content center
  • Thread starter Thread starter Simoarr
Simoarr
Good morning to all, my name is simon and for just over 1 month I have changed work and I am using inventor .
I'm finding myself in a situation where I created my libreira, copied the family I need from the content center, and I stuck to the modification of the "column expression" within the " column property"
I should create a column that, through existing parameters, reproduces my corporate encoding. . .
the problem is that I should use formulas similar to those of excel (e.g. string.estrai, etc.) and not accept them.
in the online guide are not specified which formulas can be used. . .
I need your help.. .
I attach an example of a column created for example. . .
1697640516009.webpThank you very much
creating it in this way unfortunately is really complex.
because where I work I also take care of the whole part of management, following courses and what else I was advised to always pass by excel through special command, and indeed it turns out all simpler and immediate.1697694720815.webp
hi you pass from excel but not always formulas remain, only values remain, I can advise you to lose that extra hour and do it as from image above, then other thing I can recommend is to tie iproperties, for example number of warehouse with your code
thanks for the answers.
actually if I step by excel, at closing I only care about values and not formulas.
to apply formulas... Is there a list of the formulas accepted by that camp somewhere? I searched but I can't find anything. . .
I didn't find a list.
but are divided into strings, boolean, real and integer, I try to make some examples
I create the column "displayname" type string
vt.&{codice_magazzino}&" tcei- "& {designation}&" "&{material_alias}
in this way to each line you fill yourself with the values between { }
I create the column " typology" type boolean
can be 1 - 0 put it as key column and then you create the 2 options for the same row
etc.
Is this a profile (to be used in the chassis generator) or single components (so there is an ipt, saved in the folder of the content center)?
