forum to test thatgonale
  • Thread starter Thread starter archguida
archguida
Good morning to all I meet, my name is antonio and recently I approached catia v5, I would have a question.
I should create a threaded hexagonal head hole, using the normal hole function creates me the thread but the holes are all round head. I would have thought of doing it in 2 times a hexagonal cut with a pocket and inside a threaded hole but nn seems to me a very clean and fast solution. Does anyone have any advice? Thank you.
Sorry, what do you mean by hexagonal-headed photo? Do you mean hexagonal screw threaded photo? if you, there is the option of unloading when you make a hole.
hello thanks for the answer you mean a threaded hole for hexagonal head screw, so if I choose the option of flushing I can choose a different form of flushing from the hole?
i.e. better explain the first part of the hole is hexagonal in shape for a depth of 7 mm the underlying part is circular in shape and has a depth of 50 mm
Sorry, I felt bad too. In your case, to make a hexagonal hole, I think the only way is to make a pocket.
ah ok as I am a neophyte catia I thought there was a cleaner method and I was wrong thanks
