forum/vite series
  • Thread starter Thread starter Gian704
Gian704
Good morning, I would like to ask you a question, there is a system with which the screws and washers I insert in the axieme automatically follow the
set of holes I made on the piece or in the axieme? (use inventor 2014)
thank you for the answer.
if you put them from the content center they settle by themselves (or through a special button), at least from 17, 2014 I don't know
series dependent on the partsselect the series of processes to which to associate the series of assemblies. the serial processing name is displayed in the selection panel. the components are arranged in series according to the position and spacing of the working series. changes made to the machining series result in automatic updating of the number of components and spacing in the axieme series. the constraints associated with the serial component are duplicated and respected in the axieme series.1550129338190.webp
series dependent on the partsselect the series of processes to which to associate the series of assemblies. the serial processing name is displayed in the selection panel. the components are arranged in series according to the position and spacing of the working series. changes made to the machining series result in automatic updating of the number of components and spacing in the axieme series. the constraints associated with the serial component are duplicated and respected in the axieme series.View attachment 52548
thank you very much for the answer, and excuse for the delay of the answer, unfortunately to me does not work, does not select the series :cry::cry:.
I will continue to put them by hand. Bye.
if possible, post the ipt file in which you have the problem, I try to check
as I told you...
insert the screw on the 1st hole
run the serial command by selecting the 3d.ipt part series with the 1st tab
