frame binding by sketch
  • Thread starter Thread starter gil
gil
I was provoking inventor, making some sketches of drawing, when I found this trap.
inside a collection I create a sketch, then through the generator of frames rub the sketch to create a tealium with metal profiles.
At this point I realize that the frame so created is inamovable in space, I have no chance to move it. Constraints do not seem to be there but they cannot even apply others in contrast to the current position.
if instead I create the frame in a separate part and only after inserting into the axieme the problem does not arise.
Would someone be good to tell me where I'm wrong? Thank you.
You mean if the sketch is tied to the edge of the axes?
no, it only has references of verticality reept to the axes and orthogonality between its lines.
the strange fact is that the sketch for if it is not bound, before applying the profiles it all works well.
when I stick the profiles with the generator locks everything.
to create a frame directly inside another together I create a subaxieme and inside this I create the part with the skeleton sketch. This has solved various problems that I now honestly do not remember but I think they were similar to yours.. .
