frame generator and distinct elements
  • Thread starter Thread starter tzadik
tzadik
Save to all, I happen to generate frames (with the frame generator) where part of the elements of the structure come directly from the frame generator) and other parts (which will normally be sold together) are modeled separately for a matter of production management.
the distinct that I get is basically a mix between a distinct material and a distinct cut... And that's good for me.
the only problem is that when the chassis generator produces equal parts (e.g.: two tubes of the same length, without any type of processing) I in the separate I always see two different tubes (with a different part number), which in reality are (and will be) equal.
exists a (automatic) way to condense the various components of the same frame under the same heading in separate?
(other cad 3d already do it automatically, by default).
