pompeo79
Good evening to all,
I was trying to make this example ( http://www.youtube.com/watch?v=wnikbwxx1n8 )
I have problems. in practice the insertion of the frame some parts are "wheeled" and non-solid with the system of origin.
first to get to the sketch with which the tutorial begins I proceeded in this way:
- new iam
-created part
-schizzo 2d where I carry out the vertical longitudinal profile of the scale, I conclude sketch(I also insert the points, listing them equidistant on the oblique line)
-new work plan translated parallel to the sketch
-New sketch on this plane, I project the entire geometry of the first sketch, concludo sketch
-new 3d sketch, complete line frame skeleton, concludo sketch
premiss this (in any case does it seem correct to you the way so far? )
- return to the assembly and check the frame parts (all iso 4019 square 120x120x4)
instead of getting the desired result however I get something like this:
How come?
how should I do?
Thank you in advance! !
- new iam
-created part
How come?
