frame generator
  • Thread starter Thread starter pompeo79
pompeo79
Good evening to all,
I was trying to make this example ( http://www.youtube.com/watch?v=wnikbwxx1n8 )
I have problems. in practice the insertion of the frame some parts are "wheeled" and non-solid with the system of origin.
first to get to the sketch with which the tutorial begins I proceeded in this way:
- new iam
-created part
-schizzo 2d where I carry out the vertical longitudinal profile of the scale, I conclude sketch(I also insert the points, listing them equidistant on the oblique line)
-new work plan translated parallel to the sketch
-New sketch on this plane, I project the entire geometry of the first sketch, concludo sketch
-new 3d sketch, complete line frame skeleton, concludo sketch
premiss this (in any case does it seem correct to you the way so far? )
- return to the assembly and check the frame parts (all iso 4019 square 120x120x4)
instead of getting the desired result however I get something like this:
How come? :confused::confused: how should I do?
Thank you in advance! !
Good evening to all............................................................................... thank you in advance! !
What are you doing?
we don't ask for a flower but a small presentation.
Today is a day!
sometimes it happened to me that some parts are slightly "ruotate". I haven't figured out why. However just remove them and insert them again to correct the problem.
