frequency calculation cpu solidworks
  • Thread starter Thread starter tanticapelli
tanticapelli
I noticed from management activities that the cpu (intel xeon w-2145) of the workstation (hp g4 workstation) does not work at the maximum frequency of turbo boost (4,50 ghz) but comes to maximum 4,20 ghz.
windows energy saving settings are on waste.
I have reason to believe that it is not an alimnentation deficit as it is a constructive solution proposed by the same customised hp within the options themselves recommended.
How can I make him use of all the computing power?
so many hairs
from the detailed resource monitor seems that the cpu goes 100% of its possibilities, so if the administrator wanted to hide this useless post...
so many hairs
Is the turbo speed managed automatically or should it be set in the bios?
from "bocia" the turbo in the 386-486 was a nice rust on the case.. :
should be managed automatically perhaps with a precaution margin set by hp.
But I should look at the bios for sure.
Usually mobo builders of a certain level have a dedicated program that allows you to manage much of the settings that you find in the bios directly in windows environment, implemented with a simple reboot.
Try to see if there's any balorda setting limiting the clock...
