Grillone
You're right, you can't do anything with the mass.I am puzzled... I would be curious to know what method of modeling you will use to generate mountain-shaped masses
:36_1_5:
I imported my dwg into revit as I told you before and I associated it with the ground. I'll attach your pictures.
being a grid of square revit wide zoom makes it black.
But if I zoom in on my houses and activate the solar path the shadow of the mountains is real. I'll send you some jpeg.
It's a bit of a maniac job, but it works:
