meccanicamg
Hello, everyone. I'm dealing with a little particular issue where I can't have specific information.
in the field of industrial gearboxes, where I have two or three gears, selectable by clamp, there are triggers.
Traditionally use male/female sleeves with din 5480/5481 profile 10/15 mm long for grafting and transmitting the torque making a radial trigger joint. I'm clearly a bit accurate and it takes a little bit of strength to graft but on average I didn't find any problems of disconnecting except on models with lengths of 10mm with too much bevel/beach.
the most "heavy" version goes to front frames made to slice of cake, with the sides passing from the center like these:
Basically, on all books and manuals, including niemann never tackles the theme of intemptive disconnection....that is the possibility that the graft can escape.
normally use pneumatic cylinders with levers moving the fork and make the selector move and graft. The actual thrust forces on the graft are normally around 50-150kg approximately and usually around 100kg.
historically in the various companies of construction of these triggers someone complains about the occasionality of the disconnection in march but never indicate what change, because, if there were bumps and so on ("the ones we did...." "to xxx we tried to do"....).
the only text that mentions the problem is the "construction of machines 2 - organs for the rotary motion of brass pomens" and we are in 1916...and says that for the triggers that present a certain propensity to the disconnect it is necessary to make the tooth with subsquadro where the tangent of the corner is worth about forty....so an angle of approximately 1.4°. also says as an introduction: the two-piece joint made with front triggers is not suitable for shocking machines.
then with subsquadro is like this:
Domandona: why should he disengage himself?
- I have seen that on a small joint if made with 3 or 4 teeth we have high bendings for transmitted copies, in similar applications and this can be a problem
- I personally make 11 teeth radially as high as possible and with 10 mm of grafted faces arranged so the tooth can not flench or torque
- I leave air between male and female, on the walls between 3 and 7 cents of air therefore practically remains aligned always and in full contact
- I have no application with shocks
- I tested a larger model 1mw-1200rpm held with 2 tons of push in position with reversible motion and strong accelerations and shocks without problems
- also the text of pomini (certain national/international constructor inserted in the current tenova group)...says that holding 0.2 as friction coefficient and multiplying it for the transmitted torque and dividing it by the average radius I get the force that serves to disconnect ... and are not small values since the pomini says that it is as if a single tooth is loaded and does not depend on the number of teeth intake.
What could bother me? What do you think?
Basically, on all books and manuals, including niemann never tackles the theme of intemptive disconnection....that is the possibility that the graft can escape.normally use pneumatic cylinders with levers moving the fork and make the selector move and graft. The actual thrust forces on the graft are normally around 50-150kg approximately and usually around 100kg.
Domandona: why should he disengage himself?- I have seen that on a small joint if made with 3 or 4 teeth we have high bendings for transmitted copies, in similar applications and this can be a problem
