Kawa46
Good evening to all,
I have to solve an exercise that asks me to calculate the game g1 in figure
I wanted to know if the procedure I adopted is correct.
I basically identified the quotas to,b,c,d which are seen in pencil and found g1 as a difference of these.
the values were a=425 +/- 0.3; b=85 +0.025 -0.4; c= 300 +/-0.2; d=25 +/-0.1
for c d the tolerances are taken from the 2768 fine degree, for b I took the data from theskf on the thickness.
so doing comes a 15 mm game with width of the tolerance area of 1.625.
is it correct?
I wanted to know if the procedure I adopted is correct.I basically identified the quotas to,b,c,d which are seen in pencil and found g1 as a difference of these.
is it correct?
