hello king, blessed tea that you understand the swx-ese:biggrin:I understand that.
simple, when you said to save as a library, you did not select anything.hi, I was drawing a profile to use it then as a member and rescue
"...functions not related to the chosen functions..." but what does it mean?
*!ç@ 8-( xy..porc
It's true!simple, when you said to save as a library, you did not select anything.
select the sketch.
yes and no...depends what must become a library function.It's true!
so "...functions not related to the chosen functions... blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah . .
i.e., what about selecting the sketch is needed if you are within a part that already has other functions, to select the correct profile? You say that?yes and no...depends what must become a library function.
you can make any entity "become" as a library function... The trick lies ini.e., what about selecting the sketch is needed if you are within a part that already has other functions, to select the correct profile? You say that?
already, fast and safe system....if you want a dispassionate advice, next time, open a profile already present and make a p&g with the name you need.. .
idem... But...already, fast and safe system.or simply I cover neckline and rhino.
Marco:smile:
Well, I was directly selecting the sketch, I see that you select the part that then deletes from the selection. ...you can make any entity "become" as a library function... the trick is in selecting the part icon in the building tree by clicking with the dx and selecting "Add to the library".
at that point you will have an active box with all the selected part. . Anyway, download the video... You'll be clear.
? pg?do a pg
I usually did, but it was a new section. .or simply I cover neck and rhino.
... he certainly meant "with the experience of rejuvenation, useless to tell her, things will be discounted for him..." ...or not?...I mean, let's talk about reggio... :biggrin:
will be ilpack&go not?? pg?
No!... he certainly meant "with the experience of rejuvenation, useless to tell her, things will be discounted for him..." ...or not?...![]()
I find myself better as a video, then you judge.Well, I was directly selecting the sketch, I see that you select the part that then deletes from the selection. ...
is it the same thing or with your method you get qlc d+ that I miss?
?? p&g? ?
