funzione backup thinkid designxpression
  • Thread starter Thread starter Momy985
Momy985
I know that in the pro-e there is a command to back up a whole together with individual details in a established directory. .. very useful if the axieme is composed of many details and if it is contained on a directory with many other files that do not center.
with think design does this command exist? I can't find him.:frown:
if you also have thinkplm find the pack and go command from the context menu of a selection view on documents, obviously selecting the assieme father.
if you do not have tplm but only td, open the axieme, then write in the input\output window (activable with f4) the command:
tt_td::tdmakearchive
you will be created a .ttweb file containing all external references in your temporary dir
ok, but it does not solve the problem of creating a folder with all the details of a set if for example I have to ship all together and maintain the same links of components to the resources.
I run the command, double-clicking the created file, opens the axieme creating in the dir of the created file another folder with details...but the original references are maintained? ?
the command creates in a different folder references between the various external components and the axieme.
ergo, if you pass the ttweb file to a third person, by double-clicking it recreates exactly the same structure together present by you, without losing anything.
I'll explain. .
the saving of the files is managed according to the specific dir, according to how they are encoded particular, welded assemblies or assembly or commercial details...with a built-in command in think if except a component with the coding that represents a particular sigolo saves me to e.g. in d:/projects/particulars, the customer has the precise dir. for each type of component. ..when sending the axieme to speed up the rescue it must point absolutely to the original and not temporary dir otherwise it should save individually every type of files in the dedicated folders. ..while pointing precisely to the dir that we have in common just that it executes the rescue command of the general axieme and every single component or subaxieme is automatically saved in the dedicated folders according to the encoding... is it clear now?
I'll explain. .
you can use the command export data to xml, take a look at the online guide.
It's a little more complicated, but it should solve your problem.
