funzione texture
  • Thread starter Thread starter teseo
teseo
hello to all, I am having a big scratch head with this function, I performed a piece with a particular texture, I should export it to pdf3d but the texture is lost, I tried to convert it in step in iges, but nothing; The only format is stl, does anyone know how to solve? Thank you.
si i formats 3mf and stl and similar works but then I have to give it to customers who want to open it with pdf3d ....
What is appearance?
1726143337159.webpSorry I have the English version I don't know the translation they used...cmq when you save by name for every type of file there are the options try to change to play a bit sooner or later find the one suitable for you... I leave so and it doesn't bother me.
already done nothing... .
mmm...then if you used a texture of yours may be that it does not find it when creating pdf, try to put a default tex, if the pdf funnziona then try to move your texture to the solidworks folder.
I think the problem is that the tex sees it as a graphic body and in the conversion it removes it I don't know why, I also opened a ticket but nothing silent
found you have to convert the graphic body into mesh bodies and so it works thanks anyway hello1726146465861.webp
Staff online
