Nioh17
hello to all, for gas threads which is the formula to calculate the outer diameter? for example a 1" gas has a nominal diameter (inside for tubes) of 25,4 mm and an external diameter of 33,249 mm. is there a formula, relationship or expression to have the value 33,249? I know there are tables but I need the formula for a job.
Thank you all.
Thank you all.
