gasolines
  • Thread starter Thread starter Giacomanu
Giacomanu
Hello, guys! !
I have two small questions:
1)I have just developed a sheet metal detail (for a friend) and until here everything well, but (justly) the development is composed of strings segments and spline, this my friend fails to display in his program the spline and therefore the perimeter of the piece turns out not closed, I wanted to ask if there is a command that converts the spline into arcs or/and segments.
2) When I develop and make the table, the development is randomly put and I select the Cardsian axis icon, the ruoto as I like, but I can never put it parallel to the edges of the sheet, you don't know how I can do it. .
thank you all and hope to have been clear in what I said.
by the way I use nx 6 Italian.
Thanks again
Hello, guys! !
Thanks again
1) insert, curve from curves, simplify. I have nx8 in English.
the command in Italian I think is simplified, or simplifies curve.
It's not associative, but for what you need, I think it's okay.
2) I do not have sheet metal and I did not understand the question.
hi beppino, thanks for the answer, but I do not have the simplified command of the curve in the drafting.
