Teopado89
excuse how do you set fill analysis with sequential gates?
I made two hot gates with two small hot runners (separate between them the two runners), and a yellow cone on each runner.
then only one of the two hot gates I made dx property and with valve gate I set opening after three seconds.
problem:
begins to fill, after three seconds opens the second gate and it is like closing the first one, because that connected flow front hesitates and no longer advances, and in the xy injection pressure chart at the moment of the second gate ignition the pressure goes from 80 to 40 mpa and then begins to climb as if it restarted the injection. . .
help please
problem:
help please
