atofras
hi, I want to design a gear for a pack holder and not know where to start, what can I take as an example to make a scheme?
usually the transmission ratios are indicated with the i tiny. .then serves the reduction report, which is fundamental (I place it with letter u)?
my mistake, gear ratio u and instead reduction ratio i, perdonatemi.usually the transmission ratios are indicated with the i tiny. .
so everyone should understand.
Marco:smile:
Jeff.. that you repeated? :biggrin:Hello everyone, I am currently having to design something similar to atofrà maybe I can take advantage of you, :biggrin: in the good sense of course! I have to lift a load of 50 kg (full weight, excluding the engine) for a height of 3 m and to raise everything I thought to use a rack instead of a belt drive. do you help me in the sizing of components and in the choice of engine?
