Ilario
It's a little more complicated than that, I have to work on tight enough spaces, and it's not just about having to reduce angular speed. . In short, I have the need to calculate the series of gears that make up the series trying to use as little as possible. But maybe you enlightened me on the question of wheel relations... I see now.Can't you mount n gearboxes in series? ? ?
I mean, the engine makes 600 rpm, so 864000 rpm per day
your reducer has 1:600 and takes you already to 1440 turns per day
one more with 1:600 six at 2.4 turns per day
with a pair of gears you can get ratio 1:2.4
but also with a toothed belt.. .
