general scale drawing
  • Thread starter Thread starter Dario1982
Dario1982
Good morning to all, I write to ask you for help with a problem on the scales of the drawings that is making me waste a lot of time. does not exist a command to change the scale 1:1 of the design? so that 1 card unit is = 1 design unit? for example if I have this situation from the beginning:
scala.webp(although it is in German since I work in austria, but you understand) there is a way to make sure that the scale 1:1 can be set correctly instead of 1 card unit = 0.001 design unit? here is "gray" and therefore you cannot change. . in the old versions there was a command, "state bar" that allowed access to a menu with various options including the general scale of the design, which could be changed, but now I can't find it anymore.
Thank you very much and good day!
hi dario, I on autocad map3d have these commands to change the scalefinestra1.webpand then this:finestra2.webpI can also set it from another menu:
options---> user preferences ---> default scale list and then I can change/add the scale that interests mefinestra3.webp
