generate a dwg file for each layout with autocad lt 2011
  • Thread starter Thread starter ilbona
ilbona
hello to everyone, I would have a problem whose solution could benefit many. work with autocad lt 2011 and at the beginning of each architectural project I use a file that I call "work" in which design for example the ground floor plan. during the study of the project generate a series of layouts (a1,a2,a3...) that will represent the various plan boards. every time I ask for a delivery I have to generate a file with a unique name that contains only the layout that represents the table. in practice from the work file I have to delete all layouts leaving the a1 and do "save with name tav. a1"; go back with undo clear all layouts minus a2 and do "save with name tav. a2"; go back with undo clear all the layouts minus the a3 and do "save with name tav. a3"; and so on.... I lose a lot of time for every delivery.
does not exist in your opinion a leaner method to make this division? Is the record of photoshop actions applied to autocad?
the command is _exportlayoutin 2011 it was already included, I do not know however in the version lt.
thanks for the usual availability and rapid response. I'm trying to find the command. m.b.
Brilliant. Just a flaw. I have a table to represent at 200 in the layout. imposed paper space with 10mm=1 unit (work in cm in model space). in the drawing paper space the paper with the center a window set 1:200 which contains the drawing. I exportlayout and generates a dwg file that contains the table in scale 1:1. climbing 200 times to take back the scale I need, all the odds and texts jump... Would you have an idea for that?
