some small remarks:
1-the file you posted has .wbpj extension, and is a vulgar xml file that "organizes" the content of ansys workbench projects. the file header says "project version 3.5", so it was created with version 13 of the software. all files regarding this project will be contained in the relevant subfolder called "file". inside this subfolder and in its subdirectory the geometry files are those with .agdb extension
2-original geometries present in the project are .stp files (step) and are called
333_d4346 straight shoulder.stp
333_d3392_1.stp
333_d3524_1.stp
0.5mm.stp
333_d4464.stp
333_d4465.stp
333_d3727_a.stp
and they were in the directories
u:\roc-hbu\design engineering\jamie findler
3-if you can find the files I told you you are lucky, otherwise you take all files with .agdb extension and from those, with the help of those who have an ansys design modeler license, you can export geometries in neutral format (possible choices: iges, step, parasolid and others but not sat).
