BATTMAN
Good morning to all,
my second message, my second question.. :smile:
I need to create different .ctb files for almost every design I work on. (autocad 2012).
to avoid having large amounts of .ctb files in the folder "acad printtiles" do ctrl+c on the affected file and take it directly into the autocad file, which generates an ole object that does not bother anyone.
I remember that with old versions of autocad, at the time of printing, I just had to select the ole object inside the autocad window, make ctrl+c and paste into the folder "acad printtiles".
Unfortunately, from some releases to this part, this is no longer possible, because once pasted the file in the appropriate folder, there is no more to open it.
if I click twice on the ole object in the windows folder, the message "impossible to read. unknown version" etc.
If I take it in the styles folder and do not open it, when I launch the print window, the ctb does not appear in the print style list.
If they select the ctb in the dwg file and right-ole-open click, I get an absurd "crea package" window.
the only way I have to use it is to double-click the ole file (directly inside the dwg), and save it by name.
the problem is that, before I can open it, I have to double-click it over for about ten times, when it's okay, it's gone a lot more.
Are you aware of this problem? did you manage to solve it?
Thank you very much
Mysteries
Thank you very much
Mysteries
