gnometra
Good morning to all,
I ask a question about the theme of layout management.
to view and manage more easily the numerous layouts of a project, sometimes I use the sheet group manager (sheet set manager)the problem arises when you need to rename the file name of the connected dwg (for example, to mark it with a higher revision in the file name).
in such case is there a way to "update" the dst file with the name of the new dwg file to which to connect, without having to make a new dst file?
all because I'm looking for alternative methods to be able to easily view large layout groups and the use of ssm seems to me for now the most efficient tool, since it also allows to collect layouts in "groups"
specific that are already aware of the lisp loman (layout manager) and the qvlayout command
Thank you very much
Thank you very much
