get a set as an outer shell
  • Thread starter Thread starter oloap72
oloap72
Hello everyone, I have an axieme made in pro-e that I must send to a customer, but I must do so (for a speech related to know how.) that its components are not opened individually.
in pennies the purpose is to have the asses as it presents itself, as an outer shell without being able to “navigate” inside it.
Thank you very much
I suggest you use the packaging you need to create a part that contains the external surfaces derived from a set.
file>salva copy>type>package
do some tests with the options that arise and go. Keep in mind that the higher the level and the more details are detailed, but you create a heavier file.
no, packaging models are not associative. are not updated on the occasion of the modification of the model of origin.
Are you sure? it seems to me that there is the option to keep reference to the source file.
I hope you're right, I'd be very comfortable, too, let's try to find the option
a long time ago I seem to have used it (wf3), I remember that I disabled the option when I didn't want to waste time updating the packaging. I'll check.
you can decide to make the packaging models "upgradable" (i.e. the impronunciable shrinkwrap),
depends on how you make them:
1)save a copy - shrinkwrap = non-update model
2) creates part -> inserts-> shared data-packing = updating model
I recommend the road 2...
excellent solution.
The road 2 had escaped me.
Luckily speaking about it in the forum you always learn new things.
interesting this discussion.......... .
it seems to me that the purpose of packaging is:
1.
create a part from a complex set and then be able to make it ++ quickly
2.
send one together with a customer without giving him the opportunity to open the model tree to display development features
but do you think there are other applications for use?
bb
Bye-bye
even to do it on purpose, right now I am drawing a commercial part composed of many pieces, as soon as I finish the set through the packaging I will get a single prt so that in separate will appear a single code
Bye-bye
Hello, dani-3d,
But you'd get the same thing by saving your set as part iges, right?
bb
by making it with the packaging the final prt is easily modified if you update the individual parts that make up the set, while the iges file you have to reconstruct it all the times
bb
in the company it is used to satisfy the lack of power and especially of ram since from us almost all pcs turn with 32-bit xp and therefore cannot manage files beyond 2bg of ram
therefore with low-powered, preforming machines it is used to make a srink, so that you can open the whole machine
the only shortness is to go slowly with the quality, setting:
1 we will have a very light and easy to manage but from the bad aspect
10 we will have a much more beautiful file as it looks, but it will be very heavy to handle
as in all things the truth lies in the middle.
perfectly agree. However waiting for the 64-bit better exploit the ram simply with a different settaggio allowed me to open at the same time various big assemblies and to be able to work, something that before was impossible
