get coordinate list of entities of a dwg file
  • Thread starter Thread starter yes_dani
yes_dani
hi guys I have a .dwg file that represents the profile of a rail. I downloaded dwgtrueview to open it. I wanted to know how to get the coordinates list (x,y) of the points that represent it.
ps - obviously in the title I wrong, it is not drw but .dwg
and instead with autocad is possible?
specific that I have practically never used autocad but now for the thesis I need to do this operation.
If with autocad you can do you can explain how? ?
if the rails of your design are represented by polylinee or lines you can use the coordinate program.
find it free of charge in my website: www.domenicoieva.comto charge it inside autocad uses the appload command.
Since you are not practical of autocad (less than lisp) and the points to calculate are few, try this earthly procedure.
command osnap -> imposta su finecommand id -> select the end of each segment/arch, the coordinates will be indicated on the command line.
