get projection view with 2 styles views
  • Thread starter Thread starter MORENO100
MORENO100
Hello.
I have to make the table of a particular complex.
to limit the number of views it would be convenient for me to obtain that a projection view is "hidden" with visualization style except for a portion that you want with "hidden" display style.
so on two feet I improvised creating a first view of projection "half view" saving the right part and setting it "no hidden", then I create a second perspective like the first but setting it "half view" saving the left part and setting: "no hidden" with source values seen as the first projection. so doing I get the result I look for but I have the drawbacks having two distinct views... .
Can someone give me some suggestions on how to get it more correctly? Is there a specific command?
thanks and good work to all.
p.s. use wf5
if I have to do these things from the tab layout I put in transparency some components with component display. otherwise I do a detail with hidden view and father view with no hidden view.
I honestly don't think of anything else.
