Exatem
Why don't you fix yourThat's right.
@exatem.. and you do so, so much that it costs us....
I only have the step.
the bell I have already stretched it then, once I have the tree, model accordingly the teeth...the interruption on the fillet can be normal if you put like a safety rosette for nails.
the millerighe is to understand the functionality of the lack of a "intaglio" (to speak just that they have fried a tooth in less)... but if the "guru" does the reticent and does not explain anything...:tongue:
for the "simulacro" can be indifferent; Do you... if you do it as a photo the bell will have to be consequently to mate.
It's that two months ago I disassembled the shiman pins of the racing bike, which use the same system...That's right.
You're right. I looked bad. .on our model are staggered, they seem correct.
Since you have the eye ready, you have to make an expedition to segarti in two the bike and put out use any other sports and playful equipment, radio, TV and books included, so that you can find the time to make some piece of the gnomo for vents. Besides, you have three cads, so you should do three jobs... :smile:It's that two months ago I disassembled the shiman pins of the racing bike, which use the same system...
look: from 1 January I made 1200 km by bike and 320 hours work at the cad, and the cat wakes me every morning at 4.30 and makes me stand at 5.Since you have the eye ready, you have to make an expedition to segarti in two the bike and put out use any other sports and playful equipment, radio, TV and books included, so that you can find the time to make some piece of the gnomo for vents. Besides, you have three cads, so you should do three jobs... :smile:
Right. .Why don't you run yours instead? ....
...to the devil I would do it:wink:... and the cat wakes me every morning at 4:30 and makes me up at 5:00.
earthquaketi :redface: find some useful indication in the manual where it talks about the disassembly/assembly of the part inserted in that thousand-rigue. . .Right. .
Here we go. Presidene: because it is a "phase key" must have a logical position. to "what time" should be placed on the tree with the pin of biella at 12 (pms)?
Maybe it depends on the cad. if you are working 10 hours a day with osd in the evening use a half hour if for detoxificationslook: from 1 January I made 1200 km by bike and 320 hours work at the cad, and the cat wakes me every morning at 4.30 and makes me stand at 5.
You can understand with what spirit I could light the cad in the evening after dinner.
Right. .
for example on page 195 and on page 197.earthquaketi :redface: find some useful indication in the manual where it talks about the disassembly/assembly of the part inserted in that thousand-rigue. . .
Yeah, I was just looking.for example on page 195 and on page 197... .
... View attachment 322I didn't calculate them at the moment. to make fast I have "polished" the raster of a figure of the manual (page 195 and 197), combining the dimensions with those of the tables board There and xi... I don't know if you raise and time are correct.Beautiful. the whole thing:% 1... here is the semi-shaft modified with the "key", and for the pleasure of the president also the cam disc (only that):View attachment 32216 ... View attachment 32217I didn't calculate them at the moment. to make fast I have "polished" the raster of a figure of the manual (page 195 and 197), combining the dimensions with those of the tables board There and xi... I don't know if you raise and time are correct.
for inclination and step of the 2 cam rings I used the size of the drill holes on the front carter of maxopus (which still remains to be corrected), so at least to be able to mate the whole.
the internal toothing should be z80 m3 (if standard.. )
the attached axieme should give the correct position, with the back piston 1 at the pms, as from manual (eye to bind the extracted step before making unconsulated movements).
...have fun:
So? ? ! ?Beautiful. the whole thing:
What about me? Where are they?I have prepared a list of the things already done and who has done them.
planche iii - carter
I'm sorry.
iii_11 maxopus
_
planche iv - cylinders
Iv_41 marcof
_
radio station
_
I______________
planche v - motor shaft
_
_
_
_
_
_
planche vi - camshaft
_
then there should be sail and rs4 but I don't know if they posted a few pieces.
Do you check if there is something missing?
imho lacks a list of the working parts. Who's doing what? avoid duplication would not be bad or still know who is doing it can help in case more than one would want to do the same detail.I have prepared a list of the things already done and who has done them.
(cut)
below the complete list of the items I made:I have prepared a list of the things already done and who has done them.
I'm sorry.
iii_11 maxopus
_
Iv_41 marcof
_
radio station
_
I______________
_
_
_
_
_
_
_
preceded by little...imho lacks a list of the working parts. Who's doing what? avoid duplication would not be bad or still know who is doing it can help in case more than one would want to do the same detail.
Let's put it here and/or on google drive, as long as it is updated.
