Hello everyone,
I should draw a hook,
I have to create a surface that connects me the two green parts (as from the photo). .
I don't know what commands to use. .
Give me a tip.
then: as you see from the photo I have to create a surface that connects the two green parts..but it must have a trend similar to that base... .
I try to do a pen sketch I see if I'm clearer
Can I be honest? I saw your hook attempt. You don't miss a couple of straights to get to the end: you miss the basics of surface modeling. begins to look at the surfaces, especially the limit blend, on the online guide or in some tutorials. from there you will see that you turn on the bulb, places of the files already closer to the solution, the suggestion is more targeted and accurate. . .
