grandsiemi
  • Thread starter Thread starter bich
bich
Good morning, guys.
I need advice to handle big asses! !
we talk about 125000 parts with the un suppressed content center and about 50000 with the suppressed content center.... we talk about silos in sheet metal... .
what I would like to know is what your approach is to create a set of this type, that is, created more under axiemi with the individual components, then create the series in the final axieme or create already "serialized" sub-axieme and join them as a unit in the final axieme? ?
the doubt made me come a guide that I found in the 3d tips & tricks that speaks not to create the series at the first level...but the first level from the bottom or from the top!!!:confused:
other thing at what stage would you put the screws seen the considerable amount? ? ?
My problem if you did not understand is that to do an operation I put it all morning!!! !
Thank you! ! !
hi! if you've put it all morning, you can get improvements using good modeling techniques, but I think the hardware is insufficient. so many say: what does it take to turn 4 drawings? Then nothing goes.
series should be made with criterion and logic. if you have a silos consisting of tube, side flanged cap with 8 screws and 8 dice, mountains silos + together made by cap + 1 screw + 1 serialized nut x 8)
then if you have n silos do the complete silos series
thanks more or less and what I did...my problem is that most screws go to join the various silos together!!!! 8)
as hardware I don't think I'm so bad...even if I find it really strange to have always and only 25% cpu and 1gb of busy ram (no warning 4) and have a very slow program ,certo use xp sp3 32bit but cabbage at least 2gb ....I should try with win7 so much the license I have, at least I take the doubt...
and what video card mountains??? is not to be underestimated
have you tried with the levels of detail by suppressing the bolt?
make a silo iam with the screws that interface with the next, then make a view configuration by suppressing the screws themselves and using it for the last silo.
at least 2gb...
have you put the option " /3gb /userva=2900 /fastdetect /noexecute=optin" in the boot.ini file?
the value 2900, as it recalled ilary, should be varied according to the single pc (the blue screen is in ambush )
Bye.
...I find it really strange to have always and only 25% cpu...
Do you have a four-core processor? If so, unfortunately inventor does not exploit multi-core technology, except if I am not mistaken in structural analysis, then it will never use more than 100/4=25% of the total computing capacity of your computer.
...125000 parts with the center contents not suppressed and about 50000 with the center contents suppressed....parliamo di silos in sheet metal... .
but 125000 parts for 8 silo really seems to me an exaggeration:eek::eek:
then proceed with order:
thanks to everyone for the interest!
video card nvidia geforce 9800gt
I did not put any optionse in boot but I think that with sp3 it is no longer necessary on inventor info leggo 3gb should be right
purtoppo I can not make an iam of one silos because they are actually not 8 real silos but one with 8 cells.. .
yes I have a multicore q9400 2.66ghz :frown: how cool!! !
for now the only solution I found is to erase the series with the greatest number of screws, so at the end of the design I don't need anymore... so I can have a decent number of details. work with separate details levels for each sector and more or less I can.. .
for now thank you:finger:
the zoppian hardware and not little, to manage assemblies of such size, the only thing you save is the cpu.
graphics card: from at least 1gb of dedicated memory, nvidia picture would be better.
I would say at least 8gb
so: win7 64bit.
don't mention the records, but if they're fast, it's better.
then you can start to optimize, remove adactivity, screws, subdivide under assemblies and levels of detail as guide.
It leaves me perplexed, though if the screws are part of the problem, you can only put the ones necessary for a typical coupling, and then put the actual quantity correcting the number in the bom.
(to extreme evils... )
pultrop with sheet silos is so then this is even more particular since it is subject to anti-scoppio and anti-sysmic regulations. . .
realize that I only have the panels of the cells are about 950 with a 30ine of cyasuno screws does --->950x30=28500 if you add as many dice ...we get comfortable to 57000 particolari solo qui :eek:
what's bom???:confused:
Bill of materials.
the list of materials.
I still remain of mine: I would insert the screws only for the typical couplings of a silos, in the definitive axieme put a silos with screws and others without.. .
even in my opinion at this point you should bolt only one of the 8 cells to check screw size and what else. then when you make the distinct you will settle (the famous bom)
