MORENO100
Hello everyone,
I am moving the first steps to pass from wf5 to creo2, but I immediately encapsulated in a big graphic problem that I did not have in wf5.
I try to expose my problem even if it will not be very simple... .
I use a picture nvidia card k2200, I create 2 m070 and the problem affects the edges displayed in the display "shading with edges".
in creo2 known that if in a set, displayed in "shading with edges", imposed a component with the visualization style "hidden lines", the edges of the other components alter graphically in a horrid manner and also cause a delay/lag at end spin almost as if the program tries to recalculate them. using wf5 I never had any problems like this.
from the innumerable evidence that I did it seems that I can solve everything only by predicting the whole set in "shading with edges" display style. This is just an escamotage to solve the problem, so I trust in your more "official" solution.
Do you also find these problems? How did you solve them?
thanks and good work.
