graphics card geforce 560 gtx and crash autocad 2013
  • Thread starter Thread starter Jokerinoprogrammer
Jokerinoprogrammer
Good morning to all,
I'm just using autocad 2013 and I noticed that while I make a make the program freezes and I have to reboot it, then I searched a bit on the net some possible solution and I found that I should update the service pack, but I'm sorry for ignorance to see what service pack I have as I should do? and then my video card is a nvidia ge force 560 gtx and 'can not compatible and then create these blocks?
Could you please help me
try installing the last available, so much if it is already installed you will find a box that alerts you.
rendering is not a question of video card but of cpu
Thank you for your answer, now I have installed the service pack 2 of autocad 2013, but I have to tell you something, today I wasn't in autocad and I was installing programs on the pc or better trying to make updates and suddenly I got totally stuck the pc like yesterday when I made the render, then what do I have to think there is a problem of pc? hardware?
Sure. years ago it happened to me and in that case it was the fan that did not turn properly did not allow the processor to cool sufficiently, so it stuck everything.
Good morning Tristan,
I'm sorry if I didn't even feel like thanking you, but before I wrote you I tested the pc a little bit and a couple of days ago while drawing in autocad 2013 in 2d I created the planimetry and the instant I chose the pointers, there was a total block of the machine that forced me to reboot. could you also think of a problem of ram? as I did the hard drive test and it works, the drivers of the video card are up to date. What do you think?
But was it a random episode? or what is repeated?
It is an episode that often occurs, even during a simple update or cleaning with glary utilities.
It happened to me, too. I switched a pc to work. I had my partner, he still used a p4 with 512 of ram... and in short came a nice i5 with 8gb ram, discrete video card for some 3d sporadic with sketchup, a machine with good hardware in sum... But he was stuck every 20 minutes.
was installed win7 with a 30in additional programs installed by the manufacturer... Bah...
I made square clean, I formatted, put windows7 smooth, and now the pc travels that is a wonder!
Check that you don't have any plans of the cabbage installed... or running services you don't need. . .
I didn't do a ram test, but I have a new 8 gb ram banquet and see if the blocks still occur.
