gravitational load
  • Thread starter Thread starter dcmartonese
dcmartonese
Hello everyone
I have a problem of choosing loads in patran. I practically have to apply in a structure a longitudinal load of 10 g but I don't know what to use.
Thank you very much
Good evening
when I launch the analysis (modal in my case), I get a warning in the command list that tells me:
"lbc set calettamento has no entities in its application region" calettamento is the name of my constraint, I must in practice study a forced calettato dish on a rotating tree. simulation lasts less than a second which makes me doubt the goodness of the settings I put. I think I have problems with the constraints, I should block the face that is in contact with the tree.. .
You did what you had to do?
