ground fence
  • Thread starter Thread starter buonsante
buonsante
I downloaded the two rows of wire mesh fence and slabs (n.d.m. from the family forum) but being rvt files how can I insert them into my project and stretch them for my actual perimeter?
Does anyone know if there is a reason why "you will 100" in renders (as well as in "realistic" display) you see as a gray panel and not as a green mesh? in display "homogeneous colors" is perfect!
I attach the pictures.
some parametric fences, not perfect (I have corner problems), but for large areas they work.
revit 9.1
revit 2008
probably depends on the materials, maybe you don't have the texture with the alpha channel loaded or assigned.
Can I ask you to be clearer? What is the alpha channel?
where can I find the texture?
in the sheet appearance of the material.... option cut out if I don't remember badly.
put a color (texture) image of the network in the generic section> image. active crops and put the same image in black and white (Alpha channel). when rendering is calculated the parts of the black images will be transparent to the white color ones and will bring back the image parts used as textures. if I'm not mistaken among the default textures there is already something ready (color image and respective alpha channel). otherwise go photo editing with any program of processing of images.
