group rows in separate
MARCOC
Good to all
1695043826731.webpsomeone knows if and pobbile group the rows of a distinct for a common field
example image
I have two parts with different file name, and rightly solid me lists them both, but I can select a common field (pippo= that contains the same writing) and get as the red one? ? ?
Thank you very much
I think you should make a separate custom and use other properties to bring together the components....
hello xxfast, but how do you group the components?
that pippo property and already created by example whose I wrote the same value believing you can rump all rows that have 1 in the pippo column, but I did not succeed, because I do not know if with solid it is possible
