piccio__87
Hello.
in a drawing is there the possibility to group the fittings of the same measure in one command alone?
if the fittings do them at different times, as I think it is right that you understand when you "invent ", it is impossible to group them.Hello.
the problem is that removing the fittings from the working tree, can affect in the workings dependent, it is not only matter of your memory.I have 76 fittings in a piece that is 89x130 with 3 sizes;
I made them as I went forward and at different times;
Do I have to delete them and remake them all in 3 unique fittings? Sincerely, it seems difficult to remember them all.
ps:Is the file not less heavy after?
