h6/n5 coupling uncertain or interference?
  • Thread starter Thread starter ConfaMiky
ConfaMiky
Good morning to all,
I have a doubt about the h6/n5 coupling. I have a 40 h6/n5 coupling and if I look at the h theory with n would be uncertain while from calculations I find myself in interference. You could help me out.
Thank you very much
in the forum there is an excel file to view the type of coupling according to tolerances.
should call mating viewer.however it is enough to write the minimum and maximum dimensions to realize what kind of coupling it is
40 h
min 40,00 min 40,017
max 40,016 max 40,024
speculating to keep the values to the extremes you have:
in a case hole max 40,016 and tree minimum 40,017 (+0,001)
in the opposite case minimum hole 40,00 and maximum tree 40,024 (+0,024)
that then tolerance calculators find them also online, just try
in the forum https://www.cad3d.it/forum1/resources/tolleranze-per-alberi-e-fori.18/the excel cited https://www.cad3d.it/forum1/threads/visualizzatore-di-tolleranze-iso-per-accoppiamenti.14550/
in rete:
Thank you so much now I think I understand.
the images of the theory tell you that usually h with n is uncertain, it is to me then calculate if it is actually uncertain or if in interference.
you must not be the certain to say that it is uncertain. then if you mix and you're lucky pass... .
Staff online
