hairy mature
  • Thread starter Thread starter Federico Scussat
Federico Scussat
Good morning to all
Would anyone know how to give me straight on how to draw a cylindrical helical spring on faces?
Thank you in advance
Faithful
by faith,
You mean like compression springs, from ballpoint pens to a car?
What exactly do you need to draw?
because, in itself, the "helical" commands should be enough to create the axis of the thread wrapped with the r and the desired step, and on this axis use the "tubeular axis" command in which you insert the d of the wire. then the ends or cuts and stop (there is just an ideal model) or you will sink a little and draw something more realistic.
Greetings, reborn.
