hardware acceleration in autocad 2010 for cursor slowness
  • Thread starter Thread starter epasinet
epasinet
Hi, guys.
I installed autocad lt 2010 ita 64bit on my mac.
I noticed that when drawing the slider inside the drawing area does not have a perfect fluidity even with simple 2d drawings and therefore I wanted to try to optimize the configurationd of the program itself.
I found several guides on the optimization of the hardware ignition set by the 3dconfig command.
But strangely on my autocad if I write 3dconfig on the command bar tells me command unknown!
according to you I am pursuing the right path or there are other configuration parameters that can improve the performance of the graphic engine so as to make it more fluid? ?
Now I don't know if the lt version has that command, but I suppose so.
the command is what you used (3dconfig).
you can still reach the 3d performance window via options, system tab, 3d performance setting.
But in my opinion, the problem is not there
problems like that I found them with graphics card drivers that for some reason autocad little digested.. .
sure that lt has 3dconfig command?
at the bottom is a cad "just 2d compatible with the 3d, not "usable" to make 3d (also and something you do anyway). .
Besides, I noticed a certain slowness of the cursor when the "dynamic input" is active... for a period I "forced" to use it to see if it was convenient... I finally turned it off. . .
thanks giga! maybe the slowness of the cursor ke known I too is due to this dynamic input?!? I have installed without modifying any option if nn the background color and the right-click options. so I probably still have this dynamic input?!? is disabled by the classic options panel or is there as usual, a secret string to type in the command line as in the 1910 software? ? ?
thanks to all
thanks to all
active/unactive in the same status bar where there are also snap, vegetable, etc.
or f12 key or, as an alternative, from the online guide:
dynmodeactivate and disable dynamic input functions.
when all functions are activated, the displayed elements depend on the context.
when dynmode is set to a negative value, dynamic input functions are not activated, but its setting is stored. press the din button in the status bar to set the dynmode variable on the corresponding positive value.
0 all dynamic input functions, including dynamic request messages, are disabled
1 input of the triggered pointer
2 input of activated quota
3 share and pointer inputs are activated
if activated, i.e. if the dynprompt variable is set to 1, dynamic request messages are displayed when setting dynmode to 1, 2 or 3.
when the share input is activated, that is the value of the dynmode variable is equal to 2 or 3, the program switches to the pointer input if a comma or angular bracket (<) is inserted or multiple grip points are selected.
when the dynmode system variable is set to 1, 2 or 3, you can turn off all the functions temporarily holding down the temporary local change key f2.
settings are contained in the dynamic input tab of the drawing settings dialog box.
I tried to turn it off from the status bar where there is also vegetable garden and snap but the cursor remains snappy in the movements! is certainly not the dynamic input that removes fluidity to the cursor movement in the drawing area!
and controlling the used win resources with open autocad uses me about 700mb of ram and processors assigned to the virtual machine are engaged almost zero!
cmq I speak of "scattosity" just to want to be lazy. but to use mass known the difference regarding the old autocad lt 2000!
