Happy_Fly
for kindness someone can give me a tip for the use of straps in sw 2009 ? the base is more or less clear to me, but I must connect a belt, already created in assembly environment, to a part, in the case the cart that you have to "connect" a belt and move with it.
the synchronous of the pulleys works me but the part "strap" seems to me "rigid" or not able to rotate really bringing with it a cart hooked to it with a constraint to specify.
I say that it seems "rigid" because I tried to make him a sign of recognition (a hole) and the hole does not "move" along with the rotation of the pulleys and therefore does not come to mind as binding pulleys and trolleys.
must I try to deceive him by giving him some sort of "cremagliera" bond between a pulley and the cart?
thanks to everyone as usual!! !
