help by editing piece.
  • Thread starter Thread starter doctorudy
doctorudy
Good morning to all, I don't know if I place in the right section, I also tried to look for but I didn't find what I was looking for. I am not practical of cad so I look for someone who helps me to change a project that probably was made with solid work. the project in question is a piece of a motorcycle, and it is for precision a carburetor suction manifold. I should change the initial project by varying some degree the inclination of the duct, can someone help me?
there is a section dedicated to solidworks https://www.cad3d.it/forum1/forums/solidworks.9/.
there is also uina section called mechanical design https://www.cad3d.it/forum1/forums/progettazione-meccanica-forum-generale.122/there is one dedicated to the automotive https://www.cad3d.it/forum1/forums/automotive.63/do not write another post, but contact the moderator because you move it in the appropriate section.
you use solidworks and don't know if the project was made with that software? which extensions have files?
You're not protic of cad, so you're offering a paid job?
You're a doctor, don't you think it's better if your hands have any studies and motor skills? do not want to change a spoon from soup, with the things they use and express the energy better go very cautious
thanks for the answer, I do not use solid work and are not at all practical with cad files, the file extension is step they told me that for solid work. if to do this job wants to be paid someone just find one available that helps me even paying. I turned here because I don't know where to look. For the piece in question being an aspiration duct you don't go to change or performance or worsen them, the change I would like to make to give a different inclination to the cauburator.
you wrote solidworks in the profile and people are led to think it is a used software.
step is a neutral file used to exchange files between different software. can be opened with all 3d software.
is it not easier to make changes from who passed the step file?
if you do not move the discussion in a section more ioonea this discussion will follow you in a few
You're right, I'm wrong, and now I've changed.
who gave me this file is the builder of the engine block and already for having it was an enterprise. I stress that the engine is of Canadian origin designed for racing and used only in circuits, so all changes are allowed.
I don't know how to contact the moderator to move the discussion.
