fcara
good evening to all, I'm looking for a working example to support a rotary basket inside a vapor pressure vessel. the temperature should be around 160°C. I would need bearings to be used as rolling rollers only on the front side, being the engine side supported outside the container. to make the idea the application is like this but inside a pressure vessel link. the bearings would turn on a stainless flange, but my concern is to not have the friction necessary to roll the bearing. every suggestion is well accepted
