hello to all....I have a problem......I have to dissect an item on the 2d and when I do it, instead of the "classic" section restraints I find the colored section.....how can I prevent this from happening?
have you associated particular materials?
normally the type of sampling depends on the latter, delete it in 3d or replace it with a more appropriate one.
hoping your 2d is tied to a 3d, otherwise you have to manually change the patterns
