User1
hello to everyone, I kindly ask for help with the constraint sets command (group of constraints)! basically the problem is that the system asks for the selection of ucs to bind them! I tried in a set with three free elements, I selected the bond command of assembly and I chose the type of bond group of constraints, but I can't select the ucs! I wonder: it refers to the axle of the degree of freedom! If it does not refer to the axle that makes the degrees of freedom visible, how do I insert the ucs? thank you all!
