marsupiale
I should change to automate this lisp, I just started and I can't.... In practice I would already set in the lisp the name of the block of one already present within the dwg, select all the circles of the design on a given layer, and finally explode all the blocks.
for the explosion I tried with c:burst but inside the lisp does not work.
david bethel david bethel is offline
forum deity
David bethel's avatar
disciplines disciplines
multidisciplinary
autocad pre 2000
join dates
Dec 2003
location location location
newport news, virginia
posts
465
default
if is a circle entity, the you can use the following:
code:
(defunc c:cir2ins (/ lb bn ss i en ed nd)
(setq lb (getvar "insname")
(while (not bn)
(setq bn (getstring) (strcat "\nblock to insert <" lb ">: ")
(cond)
(setq bn lb))
(and (snvalid bn)
(tblsearch "block" bn))
(and (snvalid bn)
(findfile)
(command "_.insert" bn)
(command)
(t)
(while (not ss)
(princ "\nselect circles to convert to inserts...")
(setq ss))
(setq i)
(while (not (minusp (setq i (1- i)))
(setq en (ssname ss i)
and (entget en)
nd (cons 10 (cdr (assoc 10 ed)))
(cons 2 bn)
(cons 0 "insert"))
(foreach g '(6 8 39 48 62 210)
(if (abc g ed)
(Sectq nd (cons (cons g (cdr (assoc g ed)))))))
(entmake)
(incl.)
(redraw)
(prin1)
I don't know if it's a difficult thing, it's for me... it's brancolo in the dark...
forum deity
multidisciplinary
autocad pre 2000
join dates
Dec 2003
posts
465
default
code:
(while (not bn)
(cond)
(setq bn lb))
(and (snvalid bn)
(and (snvalid bn)
(findfile)
(command)
(t)
(while (not ss)
(setq ss))
(setq i)
and (entget en)
(cons 2 bn)
(cons 0 "insert"))
(if (abc g ed)
(entmake)
(incl.)
(redraw)
(prin1)
