help for alignment constraints
  • Thread starter Thread starter silvermoon
I'm sorry, but I have serious problems changing my job's aces... I can't reposition x y z... someone can give me a tip... I tried to see the guide... But I can't...
Thank you very much for your attention. . .
then in modalities together the first piece is bound to the ground, then fixed (it will have the dot in the browser), so you have to remove the constraint on the ground, then you show the plans of that piece and put them back on the main planes of the assieme (then x of the piece with x of the plan of the axieme, then y then z ). Once you have regained everything, further constraints the piece in question to the ground and eliminate the constraints.
It's easier to say.
as far as the display on how you want the piece to be when by default, you need to adjust it from the display tools.
the same discord can I do even when I compel an oject / component?
I ask you this because every time I amount my object I have built I have:
what should be the x is y
what should be y is z
what should be the z is x
for the pieces I always turn them every time they never come straight... You do the same work but I wanted to know if you could change. . .
thanks as always.. .
but the piece you have to build you already thinking how you want it to be oriented.usually as the plan of the inv sketch always takes the xy plan and the extrusion always makes it sencondo z unless you in the settings you have set to use it as plan of the sketch or the xz plan or the yz plan
I've seen it now so every time I have to set it up... Thank you very much. You got me a problem. Thank you very much.
Anyway...
unless there is a specific reason or you want to see them immediately with their right orientation, the pieces can always build them on the same floor that proposes you at the beginning of a part file.
It's when you go and put them together that through the constraints between them and the first piece fixed to "land" will be oriented as they have to... .
One thing... now I'm doubtful... but then in the end can I print my project divided into pieces with techniques and measures?
you can do what you want, but first read and understand inv tutorials well,
do the exercises and understand them well.... .
then ask us all the questions you want....
in other terms:
study and practice,study and practice,study and practice,study and practice.....
I would say the subject of the title is exhausted.
for uterine and different questions better open new posts.
