help macro
  • Thread starter Thread starter Taylor
Taylor
hello to all, I press that they are fresh of macro.
I recorded a sequence of commands and I would like to create a key that runs them on any object (not only on :/box-50-110.1).
What do I do?
Taylor
Below is the recorded sequence:
sd-raise-editor:editor:doc "/boccola-50-110.1" set_pers_context "toolbar-relative"
(if ci-libwm:
(sd-call-dialog "ci-libwm-dbsave-link-and-save-std")
(db-aip-ui::ddm_store)
set_pers_context "uict-control" ci-libwm-dbsave-link-and-save-std "/boccola-50-110.1"
db_save_sd "/boccola-50-110.1"
update_screen update_screen
(db_aip_annotate "c:/temp/jtemp61726/" "osd61729.csl")
(il-disable-named)
You should create a logical table with the list of parts and then give it to the macro/function. It's not a trivial thing if you're in the first place.
I've seen it's a wm rescue through application. feel who gives you that I think you do before and don't get mad.
