help nastran
  • Thread starter Thread starter Prog_Pie
Prog_Pie
hello to all
My problem may arise from the fact that I begin to approach these new codes....or perhaps from the fact (but I don't think) that I found the 2005 nastran (with patran 2005) and to follow a guide of the 2001 version...(I don't think there are any problems)
now the fact is very simple... I have a banal beam stuck on one side and weighing 150000 n on the other... banal analysis just to understand the code...
...I chose the folder ... I followed all the guide and with patran I created the .dat file,
then I started the nastran and untiring the previous .dat file and the keys (as per guide) scr=yes mem=10m I created the following files:
.log, .f06 and .f04
while the one necessary to the patran for the analysis, op2, ... is not there and you do not see!!!
Where can the error be?? ? ?
Where do I look? ? ?
and then I see and I don't know what a file called: patran.ses.01
What is it? ? ?
then I wanted to ask:
is it normal that the nastran in the execution ... after selecting the .dat file starts .. I do not see anything (some message on the monitor) and terms with two "bip bip" as sound? ? ?
Finally. . .
in the cd there were besides the nastran and patran that I installed, also licensing 9.2 and the manager analysiss that I did not consider necessary to install, as to good end the previous ones. . .
thank you so much to those who helped me
What does it say?
if you open the f06 file and look for the fatal word tells you something?
What does it say?
quoto lorenzo.. .nastran may not have created the op2 because of a fatal. It usually happens when you do not correctly define the property sets or constraints.
or you didn't notice and selected the option that creates a .xdb instead of the op2...look if by chance between the files a .xdb appears quite large
no .06 and .04 files create them but they are empty! are the first times I use the program, but I followed the instructions of a guide (fast guide to use..., sprout).
I had specified op2 and print, of .xdb file there are no...
the .log file is this:
msc.nastran v2005.0 (intel windows xp 5.1 (build 2600)) control file:
nastran op2new=0 $ msc.nastran .lcl file
nastran buffsize=8193 $(d:/msc.software/msc.nastran/conf/nast2005.rcf[2])
nastran real=530841600 $(program default)
jid='d:/windows/temp/trave.bdf'
out='./trave'
mem=10485760
mach='intel'
oper='windows xp'
osv='5.1 (build 2600)'
model='pentiumiii/1812 (windowsxp-321)'
nproc='2'
config=6
nproc=2
symbol=deldir='d:/msc.software/msc.nastran/msc2005/nast/del' $(program default)
symbol=demodir='d:/msc.software/msc.nastran/msc2005/nast/demo' $(program default)
symbol=sssalterdir='d:/msc.software/msc.nastran/msc2005/nast/misc/sssalter' $(program default)
symbol=tpldir='d:/msc.software/msc.nastran/msc2005/nast/tpl' $(program default)
sdir='c:/scratch/trave.t2168_27'
dbs='c:/scratch/trave.t2168_27'
scr=yes
newdel='d:/msc.software/msc.nastran/msc2005/i386/sss'
del='mscdef'
auth='1700@localhost'
authque=20
msgcat='d:/msc.software/msc.nastran/msc2005/i386/analysis.msg'
msgdest='f06'
news='d:/msc.software/msc.nastran/msc2005/nast/news.txt'
msc_ishellpath=d:/windows/temp
msc_jidpath=
path=d:/msc.software/msc.nastran/msc2005/i386;d:\msc.software\msc.patran\2005\bin;d:\windows\system32;d:\windows;d:\windows\system32\wbem
current dir: d:\windows\temp
executable: d:/msc.software/msc.nastran/msc2005/i386/analysis.exe
msc_msg: stderr
fpe: yes
hyper-threading active.
current resource limits:
physical memory: 2037 mb
physical memory available: 1543 mb
paging file size: 3930 mb
paging file size available: 3514 mb
virtual memory: 2047 mb
virtual memory available: 2038 mb
msc.nastran started fri apr 8 02:24:27 oleo 2011
02:24:27 beginning analysis
all sse xmm operations have been enabled.
all mmx operations have been enabled.
02:24:27 nsinit: *** nsinit error 70 *** unable to open unit 8
02:24:27 nsinit: stop
02:24:27 analysis complete 3
nsinit/nsclose
real: 0.031 seconds ( 0:00:00.031)
user: 0.031 seconds ( 0:00:00.031)
sys: 0.015 seconds ( 0:00:00.015)
Yes... even the size is 0! the only one who creates with something inside is the .log... and the .op2 is nowhere:(
It's a license problem, you need to contact the msc representative following you. Hi.
What is it? ? ?
.ses files are files in which all instructions in pcl language (patran command language) are contained. simply when performing an operation, such as creating a point, this instruction is represented by a function in that language. it is first displayed on the command line of patran (and you can easily verify it by looking at what appears on the command line when performing an operation) and secondly it is written on this session file. every time a patran session opens, a file session is opened on which all the operations performed are written.
is a very useful function to perform parameter analysis: can automatically generate geometries by writing appropriate .ses files
It's cool, too. However you do not see anything because nastran does not have a graphical interface. is only a solutor, therefore it is limited to processing, solving the mega linear system (in the case of solution 101, linear static, in other cases does not depend)
Finally. . .
I think that may be the problem...I don't even understand how paran works without the licensing manager! :confused:
