help!!! opening files from iges to autocad to creo
  • Thread starter Thread starter Garen
Garen
Good morning, gentlemen, I would need to open an iges file, made with creo, in autocad.May I have to somehow save it in pro/e because I was asked by the client. the problem lies in the fact that every single quota, except for the tolerances, have disappeared from the design, the design at various scales and moreover is in German :eek:. Can someone give me a tip on how to open the file properly? ? ?
Thank you. .
when you pass from a generic format (iges, stp etc.) and return to the starting format the quota-entity association, jump.
You can't do anything about this.
the only one is to make changes with the original format (and the same release).
Thank you, I actually had to do this, I had to register for creo trial and I solved so
